Question:
I was wondering if it is possible to further customize the configuration of a window? For example, I have some awning windows that are about 2400mm high, and I want to show the awning as only coming down 300mm from the top, followed by a fixed pane. How do I do this?
Answer:
Yes, this is certainly achievable with PlusSpec! Here are the following steps on how to further customize a window:
- Draw an Awning Window.
- Select the Edit Window Tool and select the drawn window. This will make two dialogues appear.
- In the Edit Window dialog adjust the Max. Window Height field to the desired size, then click Submit. The changes will be made to the window.
- If mullions are needed then they will need to be drawn manually then grouped and apply the same material as the window frame (this wasn't shown in the video).
Note: For Step 2 you can select multiple windows by holding CTRL when selecting them. It is recommended to only select windows that are the same height unless you want all windows to be changed with the updates.
