If you install the live version and use the 'Internal Only' wall type, there should be a material field (should be the third field in the Materials section) that allows you to add insulation to the wall.
- Wall tool > Construction > Wall Type > Internal Only
- Wall tool > Materials, Selections & Finishes > Wall Insulation
