Follow the 3 Step Solution,
1 - Please go to Extensions > PlusSpec > Settings > Dialog Units to 'Use model default' > Submit
2 - Then would you be able to go Window > Model Info > Units > Switch Format to Decimal and then select your preference.
3 - Final step is to restoring factory default by clicking on Extensions > PlusSpec > Restore Factory Default > then clicking ok.
