If you wish to remove PlusSpec software completely from your computer, follow the below steps:
PC (Windows):
- Open your Document Explorer
- Go to the address bar at the top and type %appdata%
- Open the SketchUp folder, and then open the SketchUp version folder that you have installed PlusSpec into (e.g. SketchUp 17)
- Open the SketchUp folder and then open the Plugins folder
- Delete both the rubysketch_plusspec folder and the rubysketch_plusspec.rb file
Mac Option 1:
- Click on the Mac ‘Go’ tab (ensure that you are not in any other program). Now that the Go tab is highlighted, hold down the option key (don’t let go). You will now see ‘Library’ in the menu options (under ‘Home’). Click on Library.
- Open the Application Support folder, and then open the SketchUp version folder that you have installed PlusSpec into
- Open the SketchUp folder, and then open the Plugins folder
Mac Option 2:
- Open a new Finder window then open your username folder
- Open the Applications folder and then open the Library folder
