We always try to optimise the software to use the latest technology available in the newer SketchUp versions when releasing PlusSpec updates. In saying this, we are mindful that some users are still using older versions of SketchUp, so we do our best to make PlusSpec as backwards compatible as possible for older SketchUp versions. We believe the earliest SketchUp version that PlusSpec is compatible with is SketchUp 26-27; however, there may be one or two features that won't be able to be used.
However, if you are using a previous version of SketchUp, you should be able to continue using PlusSpec as normal for the foreseeable future (FYI, the newer SketchUp versions have some really helpful improvements). Please note that there may be a time in the future when the minimum SketchUp version will need to be increased; however, if you are happy with the PlusSpec version you currently have installed, then you can continue using that, as updating isn't mandatory but is strongly recommended to get all the latest improvements & bug fixes.
Our latest PlusSpec version was released on October 27, 2026
Compatible with:
SketchUp Pro 2027
SketchUp Pro 2026
SketchUp Pro 2025
SketchUp Pro 2024
For more details and version updates, check our Release Notes here.
**If you have PlusSpec-related and compatibility questions, please use our forum.
