To walk a client through and around a project you should create scenes in the locations or the path you’d like to travel.
The quickest way to create scenes is to use the scene tool
and choose the semi-render option. (if you’re using a low-spec computer it’ll slow Sketchup). Then, go to the 1st scene (present) and orbit and zoom until you find the next location you’d like to have in your animation. Then, right-click the Present scene (at the top) and create new. Continue right-clicking the following scenes and creating new until you’re happy you’ve created a scene for everything you need to show.
The scenes will export via/to the 3D model viewer button ![]()
OR, you can export the animation as a video File > Export > Animation by the way, you can change the frame rate and resolution in the settings.
As a reference, you may also check our article guide here on How to Utilise the 3D model viewer.
For animation view in SketchUp, go to the menu tab click View > Animation > Play
